- Mute
- Permalink
- Report
Working in Revit 2021:
I am trying to use the material takeoff schedule tool to create a construction assembly for each wall type. I have most of it working, but noticed that multiples of materials in the assembly are only showing up once. See screenshot:
I have the "Itemize Every Instance" box checked in the sorting/grouping window, but that does not seem to make a difference:
The only workaround I have been able to come up with is to make a new material for where I have double layers in the assembly and use the comment section to describe the intent, but this does not solve when I have separate layers of the same material (on either side of a typ stud gwb for instance only one layer of gwb shows up).
Would it really be too hard for Revit to just give me this exact information as a schedule as I created the project walls?
@ToanDN - your solutions have saved me before.
