Material takeoff as a template in Revit
9 REPLIES 9
Message 1 of 10
1515 Views, 9 Replies
Hey
Is it not possible to make a template for a material takeoff in Revit? So I don't have to create a material takeoff every single time I make a new model, but I just can use a template on every models.
Best Regards
Steffen Christensen
9 REPLIES 9
Message 2 of 10
Sahay_R
You can add the material takeoff to your Project Template. As a matter of fact, you can add all the Schedules / Takeoffs / Legends / Sheets you need to your template. This will get a lot of legwork that you will not need to do on a repetitive basis and ensures consistency over projects.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 10
in reply to: Sahay_R
rsahayUZMK9!
But how do I do that?
Message 4 of 10
Sahay_R
Create a new Schedule - in the Project Browser, right click on New Material Takeoff. Add the parameters that you would like to show.
Click on R>>SaveAs>>Template.
It will save with the RTE file extension. You will need to open a new project with it, and then save as a Project .RVT.
This template will be available for you to use and re-use as needed. You can also set up any repetitive tasks like titleblocks etc in your template.
Rina Sahay
Message 5 of 10
Thank you so much
rsahayUZMK9!
It helps a lot.
I have now made my Material takeoff template and a new project, but how do I connect my template with the new project and will the template update the parameters by it self when its connected to the new project?
Best Regards
Steffen
Message 6 of 10
Right now I have made a template of a material takeoff located in "Project Browser"-->"Schedules/Quantities".. Next, I create a new project and the template is gone at the location. I seek on the internet and found the link below, but it doesn't work because I don't know how to place it on a sheet.
Steffen
Attached link: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/C...
Message 7 of 10
I have now created a new sheet but cant copy still.
Message 8 of 10
Sahay_R
Firstly, you need to tell Revit where to find the Template
R>>Options>>File Locations
Click on the green +. Navigate to the location where you have saved your RTE. Select it.
Then
R>>New>>Project
Revit will bring up a box that shows your template. Click OK
Rina Sahay
Message 9 of 10
Thank you!
Best
Steffen
Message 10 of 10
well getting started the basics please
how is the material in schedule connected to the model design  like quantities or length of wall one story is different wall expenses ,?
Forma Design Contest
Technology Administrators
