make curtain wall continouos
BIM_Dreamer
Message 1 of 20
BIM_Dreamer
how to make the mullion continuous to the vertical mullion? it was a edit profile curtain wall. thanksCURTAIN.jpg
Replies (19)
Message 2 of 20
Can't do it while in edit profile sketch mode. Close out and toggle mullion join
Toggle Mullion Join.png.
Message 3 of 20
BIM_Dreamer
thank you for your reply. how to toggle? it doesn't work. thank you.
Message 4 of 20
It's a curtain wall mullion?  You didn't model it in place by any chance?
Message 5 of 20
BIM_Dreamer
yes its a mullion model thru a profile. thanks
Message 6 of 20
So you did model it as an IN-PLACE COMPONENT?  If so, you are out of luck then.  Why don't you just use the profile to define a new Mullion Type and apply that Mullion Type to the Curtain Wall Grid? That way, you'll have the controls I mentioned above.
Message 7 of 20
BIM_Dreamer
can i share you the file so you can check. thanks
Message 8 of 20
Sure. Post it.
Message 9 of 20
BIM_Dreamer
here it is. thanks
Message 10 of 20
This is a tough one. I found the best solution was to Split the Wall -- NOT Edit it's Profile -- making it into two separate Walls; one on top of the other. Once Split, I changed the length of the ground floor Wall, and made the necessary mullion modifications.
See attached.
p.s. What happened to the System Empty Panel?
Message 11 of 20
Here is a version not using edit profile, but remove the lower grid segment and change the lower panel to Empty (I transferred it from the Metric Template).
Message 12 of 20
My way: Wall Area=1983 m2
Your way: Area= Wall 2130 m2
Difference: 147 m2
Message 13 of 20
BIM_Dreamer
@ToanDNmy original post is mistake, i need one more mullion as shown in the image file. thank you
Message 14 of 20
BIM_Dreamer
thank you but need to be the same as this please see image.
Message 15 of 20
BIM_Dreamer
ok i got ,it but how you did it. you make it as one curtain wall and change it to empty panel (below), what happen to the grid ? did you remove? how you add the empty panel? can you please explain. thank you
Message 16 of 20
- You can TAB select a grid and use Add/Remove Segment from the toolbar and click on the Segment(s) you want to remove.  That will remove the mullion(s) and merge the panels
- Select the merged panels, unpin, and change them to Empty System Panel to remove them
- You can select a row of mullion on a grid line and Make Continuous or Break as you like
See revised file.
Message 17 of 20
BIM_Dreamer
@barthbradley  sorry, thank you , but i think i followed @ToanDN approach more desirable. thanks
Message 18 of 20
What the heck are you sorry about?
Message 19 of 20
BIM_Dreamer
For the time you spent making the solution.thanks
Message 20 of 20
Ah, I see.  No need to apologize. If you valued the time and help we both gave you, then give us both a solution credit. You're not restricted to just choosing one.  Besides, both of us provided a viable solution. Neither approach was "wrong".
