So i am designing an office interior. I have modelled in place the kitchen cabinets and credenzas by selecting model in place and then the family category casework.
I have modeled in all the mass and it all looks really good. Problem is now i have have to assign materials to it so that i can render it in lumion. There is no option to add materials anywhere in the mass i created by modelling in place, neither in the properties browser or in the parameters when i click edit type.
Anyone no the best way to do this?
thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
I'm not understanding your workflow. You are modeling kitchen casework as In-Place Masses or In-Place Components? Why not as loadable families?
Anyways, both In-Place types have a Material Parameter -- inside sketch mode. If you want to change the Material Parameter outside of sketch mode, assign the Material to a named Parameter inside sketch mode.
So your saying it would be better to do it as a loadable family? What advantages do i have doing it that way?
Also yeah it found the materials parameter in sketch mode thanks
@Anonymous wrote:So your saying it would be better to do it as a loadable family?
Absolutely. 100%.
