Linked models and VG overrides
arkitek2ss
Message 1 of 16
arkitek2ss
OK, I have managed to convert all my model groups over to linked models.  (6 apartment unit types).  I need to turn off all levels in each linked model.  is there an easy way to do this or do I need to change the display settings for each model from By Host View to Custom and then Anno and turn off Levels?
Replies (15)
Message 2 of 16
Not sure what you consider an "easy way", but this is THE way:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 3 of 16
arkitek2ss
@barthbradley
I guess creating a view (section and elevation) to hide the levels within each linked model, turn off the levels in the annotation so I can just select the Linked View
Message 4 of 16
Are you asking a question of me?
Message 5 of 16
Jerry.jc.Wu
I would put all the linked model levels in a separate workset, so I can create a filer for the level not to show.
Message 6 of 16
arkitek2ss
no question from me.  just posting what I found.
Message 7 of 16
arkitek2ss
does it matter what the level height in the linked model?  main model 1st floor level is at 262' 1" but the linked model is 89' 2".
Message 8 of 16
Jerry.jc.Wu
Not really, you can filter the levels by workset, not necessary by elevation.
Message 9 of 16
RobDraw
Using worksets for visibility is not good practice. That is relying on additional user input. There are more BIMmy ways to filter.
Rob
Message 10 of 16
Jerry.jc.Wu
I know we can also create new project parameters to filter, it's extra work but you are right, maybe workset is not the way to go. Do you have a better solution? or just here to critic XD.
Message 11 of 16
RobDraw
Unlike what was said in that other response to this question, differing elevations can be a problem depending on how much coordination needs to happen. It's going to look pretty funny when someone looks at an elevation and your linked model is 173' lower that it should be.
Rob
Message 12 of 16
RobDraw
Yes I do. The link that @barthbradley posted pretty much explains it. No need to reinvent the wheel to do what can already be done.
Rob
Message 13 of 16
Jerry.jc.Wu
Oh right right, misunderstood. That link is basically the normal way, thought he want an easier way than that. Thanks.
Message 14 of 16
arkitek2ss
OK, here is another question regarding the linked models.  is there a way to set each linked model (copied to multiple floor levels) to a specific level i.e. for model groups, when selected it will show [origin level offset = 0' 0" ].  can this be shown for for linked models?
Message 15 of 16
RobDraw
Please ignore my previous post about differing elevations. This thread is getting muddied with different topics and I confused it with another type of project. You will have to be the judge on the subject of elevation. I would tend to think that there should be some sort of correlation between the values so that your most recent question can be feasible.
Rob
Message 16 of 16
Jerry.jc.Wu
Sorry I dont really understand what you try to achieve.
