Level Plenum Label always overlapping view
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
957 Aufrufe, 9 Antworten
Hello all,
After creating elevation or section cut the level label, as seen in this screen snippet, is always overlapping my view and I have to drag it to the right every single time.    Is it possible to just adjust the setting so it just stays out of my view automatically?
9 ANTWORTEN 9
Nachricht 2 von 10
dferreira-blackwell
als Antwort auf: Anonymous
they have a relationship with crop boundary, as they get changed as view changes you have to turn them all to 2d and change manually, I don't think there is any setting that allows to keep them away from boundary.
Nachricht 3 von 10
joe_keogh
Hi @Anonymous
Try editing the Level Head Famly, and move it to the right so that the text starts at the end of the Level line, rather than finishing at the end of level line.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Nachricht 4 von 10
als Antwort auf: joe_keogh
Hey Joe,
Thanks for the reply. I'm not seeing the reference planes in the family editor as in your screenshot, only the label and bubble. I should have mentioned I'm in version 2018.3, not sure if it makes a difference.
Nachricht 5 von 10
joe_keogh
Hi @Anonymous
In Visibility Graphics (VV/VG), Annotation Tab, turn on Ref Planes
Joe Keogh
Nachricht 6 von 10
Joe, Ah i should have thought of that. well i did manage to put the text labels on the right side of the bubble and save as a new family. I hit load and close and it does show up in my annotation families in the project browser but when i click on the level in an elevation then go to the drop down menu in the properties palette my saved level family or type is not listed.
Nachricht 7 von 10
joe_keogh
Hi @Anonymous
You can select the level, Edit Type, Duplicate the Level type, then Select the Symbol to apply to the level.
Joe Keogh
Nachricht 8 von 10
Hey thanks joe! I did not see the symbol selection in the type properties, with some adjustments i should be able to make this work!
awesome
Nachricht 9 von 10
One follow up question if you don't mind.
There is a gap where the text used to be on the left and I'm having trouble finding where this can be modified.Annotation 2019-08-13 092209.png
Nachricht 10 von 10
joe_keogh
I'm sorry I don't understand the question, what do you want to be able to modify and where?
Joe Keogh
