line weight of linked CAD file not changing
Berrys_Cooling_Drafter
Message 1 of 13
I linked a cad file to my Revit model now I am trying to change the line weight and line pattern of a line.
the pattern is changing when I change it in the visibility and graphic overrides but the line weight is not changing no matter what number I change it to.
please help me with what I am doing wrong what do I need to change so it makes the changes that I want it to make.
Replies (12)
Message 2 of 13
Are you trying to change under the VGO/Imported tab?  Probably the linework is not set to BYLAYER in the CAD.  Open CAD directly and change linework to BYLAYER.
Message 3 of 13
Are you trying to change under the VGO/Imported tab? yes thats were I am changing it the patten that I change it to does change but not the line wight that does not show up as thicker line weight even when I change it to #10
Message 4 of 13
I checked the Cad File the lines are set to by layer for the line type and line weight everything is by layer and it still doesn't change in revit
Message 5 of 13
Post the CAD file. I'll take a look at it.
Message 6 of 13
See attached
thanks for your help
Message 7 of 13
seems to be working here. What layer linework are you trying to change?
...Maybe it's changing, but it's unnoticed because of view scale?
Message 8 of 13
a few of them take a look at the snips attached
see the ones i changed and you can see the pattern changed but not the line weight.
Message 9 of 13
not every element in the CAD is set to BYLAYER.  Window-select the whole enchilada, and change from *VARIES* to BYLAYER.
Message 10 of 13
I see now that its not only the CAD lines that are not changing its weight also Revit elements that I change the object style to a heavier line wight it also doesn't show up that way in the model why is that so?
Message 11 of 13
Turn Thin Lines OFF ("TL")
Message 12 of 13
🤣😂all for that!!
Message 13 of 13
Hey, it's Sunday.  Good excuse as any.
Cheers!
