Lighting Analysis, Server Down
Does anyone know what is happening with this?  How long is it likely to be down?   This is what I get when trying to do a lighting analysis.
Nardo
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi @Anonymous,
We have no issues on this end with the server, are you still receiving this error today?
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
The server was back up in the afternoon.  I was on the phone with someone 250 miles away when it was failing and had them check to see if it was working from his location.  He had the exact same message at that time.  So Autodesk must have fixed it later that day.
andrea.kikuchi
Autodesk Support
Autodesk Support
Great, glad it's back up. Thank you for the reply!
Andrea K
