Levels not showing in Elevation
DanePower8891
Message 1 of 27
DanePower8891
I have inherited some Revit files, all of which have a ground floor and ceiling plan (hence an associated level).
The levels do not show the in elevations (or sections for that matter). It is not a view setting, I have checked this, nor are they hidden by category or element. I have added new levels and these are visible. The levels exist, I just cannot view them or select them.
Any ideas?
Thanks in advance,
Dane,
Accepted solutions (3)
Replies (26)
Message 2 of 27
see image
Message 3 of 27
Is the level line visible? If so click on a line to highlight it there
should be a check box on either end, and check one of the boxes the level
title should appear.
"DanePower8891" wrote in message news:[email protected]...
> Hi,
> Any ideas?
> Thanks in advance,
> Dane,
Message 4 of 27
the what?
Message 5 of 27
You say it's not a view setting but under the view's properties is the 'Far Clipping' setting set to 'No Clip'?
Message 6 of 27
do they show in any section or elevation view? If they do you can try
selecting them in a view they are showing in and right click. Then select
"maximize 3d extents". This may bring it back in the other views. After
this is done you can try turning off the crop region of all the views and do
a zoom extents. you might find the levels way away from the model geometry.
You can use the grips to pull them back to where they belong.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
Any ideas?
Thanks in advance,
Dane,
Message 7 of 27
Dane,
I believe what you are asking is this:
You can not see any of the Level Lines and Targets in your elevations or sections which were generated by the original creator of the file
you received. When you place new Levels, however, you CAN see the new ones in the elevations and sections.
Try this:
In an elevation view, stretch/adjust the viewport/crop region up and down, and see if the Levels show up.
If not, "uncrop" the view by turning cropping off, and turning crop regions off. Do you now see them?
Then, check and see if there are any Scope Boxes in the model by going to View Properties under Annotation Categories
and turn Scope Boxes on.
Also, under Help, check for "propogate extents"--and read thru that and see if the original Levels need to have their extents propogated
to the views where you can not see them.
Any luck?
cheers
Message 8 of 27
I assume it was a typo.
The sentence should have probably read "The levels do not show IN THE
elevations (or sections for that matter.)"
Jeff Hanson
Autodesk - BIM UX
Manchester, NH
you guys are all just running in circles
trying to answer something you know
not the question..
"The levels do not show the"
the what?
there are a lot of things that might not
show in a level.. let's wait until they tell
us what exactly is not showing..
Message 9 of 27
DanePower8891
thats it! thanks joe. this was the problem.
thanks to all other replies also.
Message 10 of 27
DanePower8891
thanks all for your replies.
the issue was the 'far clipping' setting.
sorry about the typo and confusion!!!!!
Message 11 of 27
Jeff,
I have to click on each level individually in each view and un-check "maximize 3D extents".  I try and select them all that option does not appear on the screen.  Is there another way apply this setting by selecting all levels in the view?  Thanks.
Message 12 of 27
Hi there,
When i create new levels, they appear in plan views but are not seen in any of the elevation views. Can anybody help me out on this......??
Thanks in advance...
Message 13 of 27
That worked for me, had same problem.
Message 14 of 27
Hi I am currently working on a project and i created a land plot and set each level line to the proper elevation but not all of the level lines appear in every view. In the North view all of the level lines and the walls i have created appear, but the walls don't show up in any of the other views. Also the North, West, and South views show all of the level lines but the East view does not. How can i fix this? Thank you
Message 15 of 27
Some of the levels are not showing up in section or in the elevations. Please assist
Message 16 of 27
CoreyDaun
Open a Section or Elevation that does show the Levels, or create a new Elevation View and turn off Crop View and set Depth Clipping to "No Clip". The Level must actually enter the boundary box for the Section or Elevation in order to show up in it. Go to a perpendicular Elevation View that shows all of the Levels and adjust the ends of the Level lines as required. See image below.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 17 of 27
Maximize 3d extents did the trick for me. Thanks!
Message 18 of 27
lmpka
Just adding my two bits too.  I had levels set up and assigned a scope box to them. I then created several elevations for my shearwalls, and assigned a template to them.  The Levels weren't showing in the elevations.  Turning off "Crop View" and then turning it back on worked. (Small bug?) Revit 2015.
Message 19 of 27
SolidPoint
Hi I wrote a little tutorial on this a while back, thought it might be helpful: http://essentialbim.com/2014/01/09/how-to-always-view-levels-in-revit-regardless-of-your-sections-ra...
Easiest way to select all levels is to left click on a any level in view, then right click go to "select all instances" then "in entire project" left click. Then Right click again on one of the now highlighted levels, then left click on "maximise 3D Extents". This should hopefully solve all level viewing problems.
Do note that as you expand and work on the model and start building in other areas, you may need to do this again to cover the new larger model.
James Pegg
JRPCAD Ltd. (Trading as Essential BIM)
Laser Scanning & Scan to BIM Services
http://www.essentialbim.com
Message 20 of 27
nicesave2000
This issue has happened to me before. If I link a Survey and it isn't centered close to the default Elevation Tags in Plan, everything else gets wacky.
If I move the Elevation Tags to fit the Survey location, this causes trouble. But the Survey is located to some marker in "reality".
The solution is as Jeff stated, right click an Elevation Tag and then Zoom To 3D Extents.
If I move the Survey to where in the center of the Elevation Tags, the problem doesn't happen. I just have to Publish Coordinates in this location.
But I'm thinking the best solution is to leave the Survey .dwg alone and move the Tags around.
Thanks for the thread, in any event. Cheers.
