Solved by Alfredo_Medina. Go to Solution.
I have to agree with Dave and Alfredo, you just can't give all the information in a schedue for storefront. An elevation is the best way to communicate your intent, so why not just bypass the schedule? Referring to storefront as a "window" is a misnomer in my opinion. Storefronts and curtainwalls are walls that you can see through. If you're interested in my method you can read more about it here:
This method works well when tagging in plans, but when I create a Callout view of the plan, I can't find the Ghost Window that's been attached to the curtain wall.
I've made sure that all of the tag settings are turned on in my Visibility and Graphics.
Anyone have the same issue?
Thanks for the help.
Revit 2015 and you are able to schedule the "Unconnected Height"
I'm not entirely sure what version of Revit that this was introduced.
Didnt realise this was such an old post and didnt know how to delete 😛
Paul.
