Laptop specification to run complex Revit models
6 REPLIES 6
778 Views, 6 Replies
Hey all,
I had a question. I'm looking now for 2 months after a laptop that supports revit copmlex buildings.
I contacted several companies without a result... So i hope i can find some awnsers here:
I Fount these laptops but i dont know if they will perforn good in any way:
- MSI Creator 17 inch
- RTX 2080 Super Max-Q (8GB)
- I7-10875H
32GB DDR4 2666MHz Ram
- 2TB Storage
Apple Macbook Pro 16:
- I9
- 32GB 2666-MHz DDR4 Ram
- AMD Radeon Pro 5500M 8GB
- 512 GB SSD with external hard drive
Will this perform well or do you use something else or recommend something else?
Thanks in advance
Greetz
6 REPLIES 6
L.Maas
Check out the Revit Hardware Specs. It gives advice for  minimum to performance systems.
I would not worry too much about the graphics and focus more on memory and processor.
As a rule of thumb "project size loaded * 20 = RAM needed" for Revit only (not including other running software)
I personally would not use a macbook. Revit is only for Windows, meaning you would need to use virtualisation on a Mac.
Other focus points might depend on other software yo are going to use
Louis
Please mention Revit version, especially when uploading Revit files.
martijn_pater
If you're going with the macbook you want to get parallels aswell. Running from bootcamp gives you/could give you some driver issues, whereas parallels uses mac basically. For instance your mouse/mousepad/keyboard might not function properly, from experience...
I can safely recommend you that device "MSI Creator 17 inch" according to a friend who's using it for professional renders and has only one problem which is not technical the fan sound is somehow high, everything is good for revit.
lim.wendy
@Anonymous,
Welcome to the forum and thanks for posting. I've modified your title to give other users a quick insight into the question/issue you are having.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
in reply to: lim.wendy
Thanks for the awnsers, im looking for the msi but now i have to options.
MSI Option 1:
https://www.tones.be/nl/article/131827?fbclid=IwAR3J4T3ueqDe2CD1KCFNQvRlI6gUigRAsZhX_Y2sNXa-664TTIJi...
Msi Option2:
https://www.tones.be/nl/article/131822?fbclid=IwAR2QIddRzLQ27oYHZ3w3F0590_e1khc-b1-Uwg01vPeUkhEsQcXK...
The option 2 is cheaper but had i9, so i dont know wich one is the best cause the i9 is cheaper.
Thanks in advance greets
ennujozlagam
you can also try HERE. thanks
Forma Design Contest
