properties bar will not appear
Hi all,
have checked the box to show properties bar BUT still wont appear, please help!
Have you tried turning Revit off and on? Sometimes it can just be a computer glitch. Or try ticking the properties box on and off under View > User interface.
Hi there,
yes, I've restarted the computer and have ticked the box off and on 😞 - no luck!
Mohamed-Nassar
if you are working with double screen check it in the other screen or may be it had be very small tab.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
ennujozlagam
go to user interface and tick.  or try to drag your project brower sometimes is located below or try to adjust your screen resolution percentage and see if helps. thanks
