Issue with not placed instances
j.sisodia
Message 1 of 11
j.sisodia
I have an issue where the instances of a family type in the project are coming up 43(after purging all the unused model groups) but when I try to delete the family type it says '74 instances of the family are deleted'. Not sure how to find those extra 31 instances. we have purged everything, no design options, and no nested families in the project. Not sure if anyone came across anything like this in past. thanks
Replies (10)
Message 2 of 11
Check all phases and legend views.
Message 3 of 11
j.sisodia
Hi, thanks for your reply. I have checked it and i can confirm that we haven’t got anything on legend views And phases. Thanks
Message 4 of 11
Create a schedule and use highlight elements in view to find where they are.
Message 5 of 11
j.sisodia
Hi, It only scheduled 43 windows the total number of placed instances. But when I try to delete the family, it says deleting 74 instances.
Message 6 of 11
SteveKStafford
What warnings does your model have?
Steve Stafford
Message 7 of 11
TripleM-Dev.net
Is the family shared?, then it could be nested in other families,  2 possible situations then:
A. The host family isn't used (but as you state everything is purged, so this is less likely)
B. The family is used as a nested family but set to invisible in the host family, so can't be purged.
Or, it may be used as a Legend component?
- Michel
Message 8 of 11
j.sisodia
Hi, I haven't got any warning related to groups or windows. thanks
Message 9 of 11
j.sisodia
Hi, none of the window families that I have got are being nested and shared. Just to confirm all 43 families are part of a total of 3 groups, I know revit counts instances(while deleting family from the project) when there is a purgeable group in the project. i did a quick exercise e.g., I deleted a group (which had 11 windows in it) from the model which gave me a count of 63, and then purged the model and it came down to 52. I hope that makes sense.
Message 10 of 11
SteveKStafford
Groups can have excluded elements which means Revit won't count them in schedules (just number of included) but they are still in the database (actual number).
Steve Stafford
Message 11 of 11
j.sisodia
Hi, i have checked all the groups and none of those have excluded elements. thanks
