Is there anyway to AUTO-numbering on schedules?
danezeq
Message 1 of 31
danezeq
i'm trying to number all items at once, without the need to do it one by one manually.
Replies (30)
Message 2 of 31
PavelAnd
Hi. Look this tool. It have free order marking option.
Best regards, Pavel Plotitsyn.
Message 3 of 31
danezeq
Thanks. i tried. found it very complicated to operate...
Message 4 of 31
RDAOU
@danezeq
Can use dynamo to auto-number those but that may require defining in what sequence should the instances be numbered? The image shows that the schedule/list is shuffled...or?
Message 5 of 31
danezeq
You mentioned a good point.
I'm actually keep thinking of how it would be right to sort them... reguardless of dynamo.
it's a list of signage elements on the parking building. This column stands for "seriel #" or "mark". of each sign.
My first intention was to sort them at the order of placing them on revit, but im trying to find a more reasonable order.
Message 6 of 31
danezeq
This is the sort i thought of:
1. by level (upper level = low number)
and then, 2. (dont know if it's possible) by location, from south-east to north west
Message 7 of 31
You need to establish some logic for organizing the numbers and stick with it.  You don't want to have every sign numbered chronologically then when you need to add a few signs in the middle and the numbers are totally off.
Here are a few ideas:
1. Use spatial data as prefix
2. Use a plan grid
Message 8 of 31
danezeq
Yes. that what i thought of. didnt thought about the prefix. actually a prefix that states the level could help
level -3 = Cxxx
level -4 = Dxxxx
etc...
Message 9 of 31
danezeq
So, the only way to do it is with dynamo?
Message 10 of 31
PavelAnd
If you have options for sorting, you can create a dyn file as shown below. In the attachment I am sending an example script. To modify it, you will need to study Dynamo and Python.
Message 11 of 31
danezeq
Thanks! i'll try to implement this right away.
i guess it's time for me to  learn dynamo basics 😞
Message 12 of 31
danezeq
It doest work, though i changed the name of the parameters (level and length) to be exactly like in my schedule
Message 13 of 31
Mark.Ackerley
Hey,
Just to suggest a possible alternative method...
I’m a big fan of Dynamo and use it daily, but I’ve moved away from it for these kinds of tasks because users weren’t running the graphs.
I now mostly combine parameters in labels and schedules to generate a unique code.
Then I can sort my schedule to number the few multiples (say I’m doing door numbers and have 2 doors in a random couple of rooms).
Hopefully that’s of interest 🙂
Mark
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
 In your example
Message 14 of 31
danezeq
Thanks.
So this tip gives me the ability to assemble a code  that contains a floor number (for example) with "mark" together like ff-xxxx (f for floor) it can be helpful. thanks.
about the auto-numbering issue, will i still have to enter the marks one-by-one if i dont handle dynamo? right?
Message 15 of 31
Mark.Ackerley
Hey,
You certainly can use Dynamo if you need to 🙂
But for my example there wouldn’t be much advantage... My code is:
level  - unit number - main bathroom (where all bathroom doors are number 4*)
I can use a schedule to number all main bathroom doors as 4 very easily by sorting by ‘door opening into’ room parameter
I know this example might not be practical for your example, but I thought it might be useful... If you can find a system which gives you a manageable amount of manual numbering....
Cheers,
Mark
*I wouldn’t actually use Mark in this example, because I’d get warnings about duplicates.
Message 16 of 31
danezeq
I am just not sure i understand: for AUTO-numbering (that is: one click that fill in all "mark" column in all lines) - Must i use dynamo?
Message 17 of 31
Mark.Ackerley
For Auto-numbering you must use Dynamo 🙂
But sometimes auto means more effort than manual.
Best of luck 🙂
Mark
P.S I am very happy to help you with Dynamo, perhaps post a test rvt and Dyn?
Message 18 of 31
danezeq
Yes - for now I just do it manually.
Message 19 of 31
danezeq
Is it possible to use the ID for reach element instead of mark, and schedule it?
Message 20 of 31
danezeq
ok if not - just a simple trick that will randomly fill all "mark" fields with chronological numbering. that will be fair enough for now.
help please 😞
