Is there any solution for inline text in dimensions?
7 REPLIES 7
Message 1 of 8
infoWBN4V
487 Views, 7 Replies
Hi everyone.
I know it may has been long talked but does anyone know of any reliable solution to draw dimensions with an inline text?
The offset parameter to zero puts the text just abve the dimension line.
7 REPLIES 7
Message 2 of 8
in reply to: infoWBN4V
https://www.revitforum.org/node/37804
Toan Nguyen
Message 3 of 8
infoWBN4V
in reply to: ToanDN
Awesome. Thanks.
I'll dig into that.
Message 4 of 8
veso58S5W
in reply to: ToanDN
So, there is no setting in Revit EditType Type Properties sections to do anything to place Dimension Value Text in the line?
I found somewhere that if Leader Type selection is set to Line, then it will have option in Text/Text Location option InLine or Above. That selection InLine is not doing anything?
It is strange that Revit decide to have Text Offset selection but that value must be only positive, what I really don't see any use of it.
Can anybody from Revit Team explain why is this so? @mike_engel or @lim.wendy
Message 5 of 8
in reply to: veso58S5W
Would you accept explanation from non-Revit team members?
Toan Nguyen
Message 6 of 8
veso58S5W
in reply to: ToanDN
Thank you Toan,
I went there to see what is that and must say - I don't have a clue how to use that features.
You see, from program what cost $6/month I expected to have little bit more offerings.
I work with CAD and 3D modeling for 35 and 28 years. Never had experiencing anything so simple like placing dimension text where ever I want. So basic, so marginal.
Message 7 of 8
lim.wendy
Thank you for your feedback @veso58S5W
I would recommend submitting your idea to the Revit Ideas forum, it is monitored by developers and product managers and is currently the most effective way to request a product enhancement.
If this has been requested already, please take the opportunity to click the Screenshot 2020-06-04 at 11.14.28.png button and add your support to the Idea. Votes on an idea will increase the likelihood that an idea will be implemented.
If the idea is accepted for development, it will progress through the Accepted and Implemented stages. Whenever an idea’s status is changed, the person who originally posted the idea as well as all the members who upvote it will be automatically notified. 🙂
@kimberly.fuhrman
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 8 of 8
This has been posted as a Revit Idea. I suggest adding your votes here:
https://forums.autodesk.com/t5/revit-ideas/vertical-alignment-for-text-in-dimensions/idi-p/6849008
Kimberly Fuhrman
Revit Community Manager
Forma Design Contest
Technology Administrators
