custom selection window
6 ANTWORTEN 6
Nachricht 1 von 7
Slamothe
450 Aufrufe, 6 Antworten
Is there a way to create a custom-shaped selection window?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Slamothe
Like AutoCAD's Lasso?  If so, No.
Nachricht 3 von 7
handjonathan
Hi @Slamothe
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 7
ennujozlagam
not possible just use your mouse to select.
Nachricht 5 von 7
Slamothe
als Antwort auf: handjonathan
No.
Nachricht 6 von 7
Do you know how to use the SHIFT key to remove elements from a selection set?  Filter dialog box is pretty handy as well for this.  Also, Temporary Hide/Isolate and temporary selection restrictions before making a crossing-window selection can help narrow the selection.
Nachricht 7 von 7
Slamothe
als Antwort auf: barthbradley
A custom selection "lasso" option would still be very useful.
