Intersection of two Curves
3 REPLIES 3
492 Views, 3 Replies
Hi
I need help with this cloister dome. In the conceptual mass environment I've created two simple curves that intersect.
How can I 'break' them and delete/hide some bits of it? (maked in red in the images below)
Any help will be appreciate it!
Thanks!
3 REPLIES 3
constantin.stroescu
you can use one or more extruded Voids to Cut your Mass Element
Constantin Stroescu
constantin.stroescu
...a rough example of using a Void to cut a mass and then to compose a more complex one using nested family....
Constantin Stroescu
in reply to: constantin.stroescu
This worked perfectly!
Thank you very much!
Forma Design Contest
