Hi
I need help with this cloister dome. In the conceptual mass environment I've created two simple curves that intersect.
How can I 'break' them and delete/hide some bits of it? (maked in red in the images below)
Any help will be appreciate it!
Thanks!
Solved by constantin.stroescu. Go to Solution.
you can use one or more extruded Voids to Cut your Mass Element
Constantin Stroescu
...a rough example of using a Void to cut a mass and then to compose a more complex one using nested family....
Constantin Stroescu
