Interactive County Map
3 REPLIES 3
dsalvagni
193 Views, 3 Replies
In Auto cad we have an interactive map that shows our state and you click on the block and can select the county that the project is in and it produces a solid hatch to indicate the county.  What is the best way to be able to achieve this in Revit.  I tried to reproduce the map in Revit but some of the lines are too small to display, I was going to make the pdfs of the map with each pdf being a separate county and then use yes/no parameter but the pdf looks like trash, does anyone have any tips on how to achieve what I am trying to do?
3 REPLIES 3
in reply to: dsalvagni
Insert the DWG into Revit via Import CAD or Link CAD.
...Post the DWG here. I'd like to take a look at it.
....see this:
https://www.youtube.com/watch?v=EugbP-p1MKk
handjonathan
Hi @dsalvagni
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Forma Design Contest
