In Auto cad we have an interactive map that shows our state and you click on the block and can select the county that the project is in and it produces a solid hatch to indicate the county. What is the best way to be able to achieve this in Revit. I tried to reproduce the map in Revit but some of the lines are too small to display, I was going to make the pdfs of the map with each pdf being a separate county and then use yes/no parameter but the pdf looks like trash, does anyone have any tips on how to achieve what I am trying to do?
Insert the DWG into Revit via Import CAD or Link CAD.
...Post the DWG here. I'd like to take a look at it.
....see this:
Hi @dsalvagni
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
