I can't rename views in project browser
Message 1 of 42
Up until Revit 2020 was easy, just clicked on the view and rename it directly or choosing rename
But now in Revit 2021 it is imposible. I don't have either options
Could someone explain to me what do I have to do?
Replies (41)
Message 21 of 42
hmunsell
Have you tried updating your Graphics card and Mouse drivers?
Howard Munsell
Message 22 of 42
HeinBond_Jeff
I can't rename views either. I was able to until recently. It's like the text field field loses focus.
See the attached GIF and you'll see what's happening (Revit 2021)
Message 23 of 42
RobDraw
Thanks for showing us what is happening!
It definitely looks like that cursed cursor thing but on steroids. I hardly ever say this but it looks like something that Autodesk needs to fix.
As a workaround, you can probably use the properties pallet or a view schedule to rename.
Rob
Message 24 of 42
Play with this User Interface setting.  What is your screen resolution and display scaling?
Message 25 of 42
shawnchambers
This just started happening to me as well.  Reinstalled Revit.  Didn't fix it.  Created a new file to see if it was the file and again, not working.  2019 and 2020 are still working just fine.
Message 26 of 42
HeinBond_Jeff
Tried changing the hardware acceleration setting on and off and it didn't fix it.
My screen resolutions set to the monitors' native resolutions, scaling is 100%.
I also tried disconnecting my external monitors and it still happens.
Just like @shawnchambers posted, it started happening recently, my original install of 2021 worked fine up last week.
Message 27 of 42
PavelAnd
Hi! Can you try updating Revit to 2021.1 version? May be it will help...
Best regards, Pavel Plotitsyn.
Message 28 of 42
HeinBond_Jeff
Good suggestion @PavelAnd  on the 2021.1 update. Unfortunately I installed and the problem persists.
We have another Revit user in the office that is running 2021 on identical hardware without this problem.
Message 29 of 42
Mouse batteries?
Have you swapped out mice?
Message 30 of 42
shawnchambers
Nope.  Wired mouse.  And Revit 2020 and 2019 is working fine.
Message 31 of 42
martijn_pater
Weird... Can you rename the level in section?
Perhaps you need to update some hardware drivers...
Message 32 of 42
HeinBond_Jeff
Yes, can rename levels in a section/elevation view.
Also, I can rename sheets in the Project browser - as they bring up a dialog box to do that.
Definitely agree that it is weird.... and annoying.
Message 33 of 42
OptimalConsulting
Community Visitor
Community Visitor
working on my teammate desktop but not working on my laptop yet it is updated!!!
Message 34 of 42
It suddenly works again. Maybe a windows update? Maybe a computer cleaning ?
Thanks all for the help.
Message 35 of 42
noraliromero
Can you solved it? It happens to me too!
Message 36 of 42
Mohamed-Nassar
i saw before a way to close this option from Revit i will find the link and post it in comment but u can right click and rename it that's already doing it well...
https://bimchapters.blogspot.com/2019/07/turning-off-double-click-rename.html
That's it
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 37 of 42
noraliromero
Hi! It works with families but not from the views, but i can change them from Properties, so, thank you!
Message 38 of 42
Mohamed-Nassar
this is the available solution for now or u can use Dynamo script to rename what ever u need,
If this answer helped you to get the point u need accept it as Solution, Thanks
Message 39 of 42
ola6n4qrvdsr
Sorry, that Revit.ini trick didn't work for the computers in my office affected by this glitch.
Can you give some detail on how to fix it with Dynamo / post a script / etc ?
Message 40 of 42
sameerkhankhattak
