I can't rename views in project browser
Message 1 of 42
Up until Revit 2020 was easy, just clicked on the view and rename it directly or choosing rename
But now in Revit 2021 it is imposible. I don't have either options
Could someone explain to me what do I have to do?
Replies (41)
Message 41 of 42
sameerkhankhattak
I was facing the same problem today and still am facing. The solution/Alternative i found is to select the view and in "Properties" panel under "Identity Date", change the name and it didnt take more than the time I had to change it by slow double clicking on view and then change it (which isnt working atm)
Message 42 of 42
michael.coviello
Autodesk Support
Autodesk Support
Hello @sameerkhankhattak
Is it possible there is a conflicting add-in?  I found an article on similar issue.
Right clicking to rename a view via the Project Browser does not work in Revit
If this helps,  Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
