I can't rename views in project browser
Up until Revit 2020 was easy, just clicked on the view and rename it directly or choosing rename
But now in Revit 2021 it is imposible. I don't have either options
Could someone explain to me what do I have to do?
Hi @Anonymous! Is this problem found on only one computer? I have not such problem. Try reinstalling Revit...
Best regards, Pavel Plotitsyn.
when you select the View, can you edit it in the Properties pallet under View Name ?
Howard Munsell
When I go to the rename option the view just keeps blue but I can't write anything.
I can duplicate, or whatever but no rename. Weird
Reinstalling Revit ? Shame
ya, that's weird. like @PavelAnd said, it works fine for me too. cant think of anything that would prevent that function either.
Howard Munsell
Nope.
Unistalled and then Reinstalled , but it is the same
any other solution ? anyone ?
can you upload your model so we can take a look at it? lets see if we have the same issue. could be a file issue, could be a PC issue.
Howard Munsell
Well , it is something weird. Never happened since Version 6
The only way of renaming any view is through Sheets
When I place an image in sheet I can rename it with (in) the viewport (title)
Well, I will be waiting if someone knows something new about it
It might be a long wait unless you share the model as suggested.
Do you guys have RENAME in the Right-Click Menu? Is this just about the single-left-click, direct Renaming not working?
Thank you @RobDraw @barthbradley @ToanDN @Fakerobert @hmunsell but it is not one project
Left click gives the option, gets blue, but I cannot change it
In anything that I open.
When I open a template is happening, or any project
Same everywhere no way to rename any view
@Fakerobert wrote:Same here, i can't rename anything in browser
At least I'm not the only one ![]()
Try starting a New Project with a different Template and see if you can rename in that one. Report back results.
Could it be that cursed cursor thing?
I have tried all templates, clean installation
Well I will have to live with renaming into the sheets situation
apparently is my computer, because for all you guys is working
Well, thanks
Weird that it is the only thing that is not working
Wait, you didn't answer my question.
Does it work if you make sure the cursor is in the box?
