How to Make Glass Panel strips with arrary Method
4 REPLIES 4
345 Views, 4 Replies
Hi Frnds,
I Need to Customize the Glazed Panel. I Edited the panel to some Addtional Strips. But Whenever am changing the panel it cant come exact sizes. How i arrary the strips in the Glaze Panel.If i Increase the Size the panel Strips need to Increase Can Anyone Help me to do this one
4 REPLIES 4
RDAOU
@Anonymous
You will need to parametrize the Array ...ie: (add parameter which relates the array or the number of arrayed element to the length of the panel)
What seems to be happening now is that you are changing the panel width (ie: make it smaller) yet the number of strips is constant; hence, it becomes too dense...I am assuming that is what is showing in the black photos or at least how it looks like
The images you added aren't really readable... If you are not sure how to do the above, maybe you can add the panel's file and someone may assist you more effectively
in reply to: RDAOU
@RDAOU
Like these i need panel with PARAMETRIC Now u got idea means pls show to me
Screencast Video
Thanks & Regards
Raj Kumar Selvaraj
RDAOU
@Anonymous
Is that something like a corogated sheest? or are those louvers?
And it looks more like a Pattern Based curtain... Are you picky on the method of how to do such a panel or you specifically want to see how a parametric array works?
There are more than 10 ways one can clad and finish a building envelop...I can't spend 30 mins doing something then it turns out it's not what you are asking about lol...so if you are not picky I can give you one method otherwise you do a research and then tell which method you want to learn and I can demonstrate it in a screencast for you to watch...how is that for a deal?!
in reply to: RDAOU
Hi
i Dont the Methods of making tat Parametric tat y am askin u sir
Could u please Explain any two methods Tat will be usefull to me. I still Stucking with the Pattern Based Curtain.
Please Show in Screencast
Thanks & Regards
Raj kumar
Forma Design Contest
