How to delete all spaces in revit?
3 REPLIES 3
2260 Views, 3 Replies
I have deleted all spaces from all floorplans, but they still show up (See Screenshot).
Tags (2)
3 REPLIES 3
Create a space schedule and delete all rows.
in reply to: ToanDN
I have already tried that but that doesn't work for me the deleted spaces still show up. I there another solution?
Corsten.Au
Hi.
1. Create Space Schedule..
2. Pick Correct Phase
3. Delete whichever not required..
After that, you have to remove the existing bits from Colour scheme, cause
deleting spaces from Schedule doesn't delete from the colour scheme.
After deleting space, fix/delete colour scheme.. Usually atleast one colour scheme needs to be kept, so you might test with Number, Name, etc to delete  all of them. There is a bit of tricky situation which you can get your head around only by testing in this Scheme Definition...After deleting space, fix/delete colour scheme.. Usually atleast one colour scheme needs to be kept, so you might test with Number, Name, etc to delete all of them. There is a bit of tricky situation which you can get your head around only by testing in this Scheme Definition...You might have some spaces in different Phase... check that one..You might have some spaces in different Phase... check that one..
Corsten
Building Designer
Forma Design Contest
Technology Administrators
