How to define non-normalized curve parameter in revit architecture
Filipe_Cuango
Filipe_Cuango
hello guys I use revit 2018, and have a revit 2013 exercise. In which you ask me to host a reference point on a reference line and then enter a value in the non-normalized curve parameter. This same parameter in my properties panel does not appear. Can someone help me locate this parameter value within revit 2018?
martijn_pater
Seems like your exercise says to do a normalized curve at 0.25 though? Otherwise switch field above the one you've marked there, measurement type.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
This parameter displays if Non-Normalized Curve Parameter is selected as the Measurement Type.
Filipe_Cuango
@martijn_pater Hi
Thanks for the explanation. But it is still a little difficult for me. I can't find the option to put it as a measurement type.
You need to pick "Draw of Face" before placing the Point on the line. You will then have "Measurement Type" Parameter available.
martijn_pater
@barthbradley Nice catch. I thought OP was already in properties menu, but it's only the tutorial page I guess...^^
