Hi, I can't use split element on selected column to split it but I can split the beam. Could you please help me with splitting the selected column? Thank you.
Hi @Anonymous
It should work with the SL command. You can also create the column at a single level and then replicate to the other levels.
Jamhmer Oc
it could be your column is pin/locked? try to unpin and do the split and see if helps. thanks
