How to Cut a Wall from a Mass Window
Message 1 of 17
Hello!
I am having difficulty cutting a wall from the face of a mass. I have windows that are generic model pattern based extrusions, however Revit will not let me cut the window out from the wall.
Any help would be greatly appreciated 🙂
Replies (16)
Message 2 of 17
Add a void in the window family , check cut with void when loaded, then use cut geometry in project to cut the wall with the window.
Message 3 of 17
Can you post the file?
Message 4 of 17
Yes!
Here is the file of the mass:
And the second one is the windows that I am using:
Message 5 of 17
Yep!
Message 6 of 17
Sorry for the spam, files wont send for some reason
Message 7 of 17
Arrgh! I've been having similar issues lately.  Bummer.
@Viveka_CD: would you know why and what a workaround is?
Message 8 of 17
ZIP them and send the zip file.
Message 9 of 17
I did that, but still the wall refuses to cut >.<
Message 10 of 17
Are you actually replacing divided surface solid panels in with glazing panels.   If so, I don't see how it could not be "cutting" (e.g.Transparent) .  Unless your panel material isn't transparent. Have you checked that the correct material is applied?
Message 11 of 17
I don't understand what you mean, my apologies. I have attached the file for the pattern based divided surface panels that I am using.
Message 12 of 17
This doesn't help me. Send the Project file.
...I do strongly recommend that you associate the Mullion and Glass Geometry's "Material" Property to Material Parameters in the Family Types dialog box.
Message 13 of 17
My apologies! 😕
Message 14 of 17
I don't see any issues with glass transparency.
Message 15 of 17
If you load it into a project and add a wall by faces the wall does not cut out the window spaces.
Message 16 of 17
Of course it won't. You need separate surfaces for the walls.
Message 17 of 17
Thank you!
How would I go about doing that?
Thank you!
