How do I unhide a single element in a category?
abdullah48arch21
Message 1 of 12
abdullah48arch21
I want to hide all the walls in a 3D view except a few selected ones. When I enter the Reveal Hidden Element mode, the option to Unhide by Element is greyed out. What do I do?
Replies (11)
Message 2 of 12
See UNHIDE CATEGORY on the Contextual Tab? Press it.
...then hide everything except that one Element via Hide in View by Element.
Message 3 of 12
mhiserZFHXS
You probably want to figure out a filter rather than hiding the category. Is there something common about the ones you want to show or hide?
Message 5 of 12
abdullah48arch21
That would too time consuming, I have hundreds of walls
Message 6 of 12
abdullah48arch21
@barthbradley That would be too time-consuming. I have hundreds of walls
Message 7 of 12
abdullah48arch21
the ones I have to show are a different family than the ones I want to hide
Message 8 of 12
mhiserZFHXS
So then set up a filter (or filters) to hide the types you don't want to see.
Message 9 of 12
  1. Start your stopwatch
  2. Unhide Wall Category in the View
  3. Select everything in View with a crossing-window
  4. Under Filter on the Contextual Tab, uncheck all but the Wall Category and press Okay
  5. Hold the Shift Key down an select the Wall(s) NOT to Hide. Shift Key deselects elements.
  6. Right-click and select Hide in View By Elements.
  7. Stop your stopwatch. How long did that take?
Message 10 of 12
Is the stopwatch still running?
Message 11 of 12
abdullah48arch21
Yeah, thanks that worked.
Message 12 of 12
azad.Nanva
The Filters is the best way, you can have a Variable and use it to Filtered the Elements.
