How do I delete an imported CAD file from My revit Project
25 REPLIES 25
Message 1 of 26
Stephm419
115297 Views, 25 Replies
Stephm419
I am working in a Revit 2015 project.
When I went to the Visibility Graphics dialogue box under Imports, there are 15 CAD files.
How do I get rid of them?
25 REPLIES 25
Message 21 of 26
cuong0904480204
in reply to: Stephm419
cuong0904480204
Community Visitor
Community Visitor
You guys can try: go to Manage > Object Styles > Imported Objects then delete the subcategories. It works for me 😄
Message 22 of 26
mark_bruining
mark_bruining
Observer
Observer
Message 23 of 26
salehFNJ5H
salehFNJ5H
Observer
Observer
In order to remove I used CTRL Z since it had not been saved yet.
Message 24 of 26
Stephm419
in reply to: salehFNJ5H
Stephm419
Thanks I will try it.
Message 25 of 26
salehFNJ5H
salehFNJ5H
Observer
Observer
You bet!
You bet!
Message 26 of 26
mahmoud.mohsenU7YUR
Hello Guys
Just an update 2023 to the matter mentioned in the question above,
there is now an add-in called pyRevit, it has many usefil tools to apply on your Revit file, but our main concern today is the one that called Links > then choose List DWGs - it will open a window have all the DWG imports categories with a search in a view option or USE THEIR ID number and search for them using search by ID method in Revit, once you select it- press delete and voila - you will get a clean file from the DWG stray parts everywhere.
it will ask you when pressing List DWGs to select from the view or the ones in the model
select what you seek, most probably will the Model to have all of them at once
And then you will have the results listed with the information as attached below:
Thank you for bringing the matter up @Stephm419
If the above helps; kindly mark this reply Accept as Solution... KUDOS are also welcomed (Only if the above helps)
Hello Guys
