Can anyone explain how the settings of a material will affect its appearance in the shaded, consistent colors, and realistic graphic display styles? I have not been able to find an Autodesk KV that explains this. For example if I look at the graphics tab of any material the first parameter is shading. If I uncheck use render appearance, and select a color, then set the graphic display style of the view to shaded, it does not show that color. If I check the user render appearance box, it shows a color that I would term at best a distant cousin of the colors seen in the image perimeter on the appearance tab. If I change the graphic display style to consistent colors, all materials change colors to something that I cannot figure out where those colors are determined. I have the same question for the realistic graphic display style.
