How can I find hidden rooms in Revit 2024?
franciane_pereira9Z2WH
Message 1 of 23
Hello, everyone,
I have a problem exporting an IFC file. There are some rooms that do not appear in the Revit program. These rooms are named Coz. Area or prohibition. Area. I have not named any elements with these names. The names are automatically generated by the revit program.
I would delete these rooms if they were showing up within the rooms table, but they are not showing up.
Does anyone have a suggestion?
Replies (22)
Message 2 of 23
hmunsell
Are you referring to rooms that have been placed and you cant find, or the list the you can pick from when placing a new Room.
Are these rooms coming from the IFC, or are they showing in the IFC after you export from Revit?
Howard Munsell
Message 3 of 23
hmunsell
if the rooms are not places but showing in a schedule or table. make a room schedule and filter it by Area or Volumn. then set the qualification to Has No Value.
any room that shows up has not been placed and can be deleted from the schedule. this should remove it from the room list.
Howard Munsell
Message 4 of 23
They are showing n the IFC after I export from Revit. And I didn't put them in my project.
Message 5 of 23
I've looked at this table and those rooms don't appear there.
Message 6 of 23
hmunsell
Do you have any filters on your Room Schedule?
Howard Munsell
Message 7 of 23
I didn't put any filters into the roows schedule. But how can I check if something like this was created? But this file is used by someone else.
Message 8 of 23
I found the location to add filter, but there is no filter on them.
Captura de tela 2024-04-24 094637.pngCaptura de tela 2024-04-24 094709.pngCaptura de tela 2024-04-24 094650.png
Message 9 of 23
hmunsell
do you have any links in your model? could these rooms be coming from them?
  • in the Fields tab, check the Include Elements in Links
  • in the Sorting/Grouping tab. make sure Itemize every Instance is Checked
see if they show in the schedule now....
Howard Munsell
Message 10 of 23
I changed the revit language. And I checked the options but it still doesn't show the rooms.
Captura de tela 2024-04-24 102859.pngimagem_2024-04-24_102958261.pngCaptura de tela 2024-04-24 102834.png
Message 11 of 23
hmunsell
When you go to place a new Room, are those rooms listed in the Room: drop down list in the options bar?
At this point I would probably need the file to look at it. Those are most of the tricks I know to find Rooms/Spaces in a model.  would you be able to upload the Revit model for us to look at?
Howard Munsell
Message 12 of 23
Yes, I can. But I send it here or send the file in your private chat?
Message 13 of 23
hmunsell
you can post it to the chat. that's fine :-).  that way others can see it too and provide input.
Howard Munsell
Message 14 of 23
Here is the file mentioned above.
Thank you very much.
Message 15 of 23
hmunsell
Fount it!
in the IFC file it gives you the Element ID. from the manage ribbon you can pick Select by ID and put that number in and find it.
In this case it appears to be referring to an Area that is placed in the model.
i feel bad about not catching that earlier 😂... .it says right there in your screen capture ( 'COZ, AREA 4: )
Howard Munsell
Message 16 of 23
hmunsell
Howard Munsell
Message 17 of 23
But it is correct that they appear with the ifcSpace key after exporting the file.
How do you activate this search by id within revit, please?
Message 18 of 23
hmunsell
Manage ribbon > Select By ID
enter the Element ID
Pick Show or OK.  "Show" will sometimes throw an error that there are not good views, but OK will at least find it for you.
Howard Munsell
Message 19 of 23
I'm sorry, I didn't express myself very well above. It is correct that 'COZ. Area' appears as an ifcSpace key after exporting the file?
Thank you for helping me.
Message 20 of 23
hmunsell
I'm not as familiar with IFC keys as I should be. if you search the IFC for "room" nothing shows up. If I remember correct, IFC refers to all that stuff (Rooms, MEP Spaces, Areas) as "spaces".
Howard Munsell
