Best way to make a glass balustrade with posts family.
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
gustavodelucaf
1235 Aufrufe, 10 Antworten
I am currently making it by applying the glass as a baluster. The problem is I need several glass families to fit the different sized it will have. It basically never repeats a size.
Can I make it to be parametrized to fit the space between mullions?
I need help.
10 ANTWORTEN 10
Nachricht 2 von 11
Niko_Davydov
als Antwort auf: gustavodelucaf
hey @gustavodelucaf ,
You can create it as a curtain wall and make it "parametric" with Dynamo.
Best regard,
Nikolai Davydov
Nachricht 3 von 11
Simon_Weel
A work-around is two Railing families superimposed. One for the balusters and one for the glass panels. As for the glass panels - don't use a baluster but use a Rail in the shape of a panel. That way you can create 'panels' any length you wish. It's not elegant, but it gets the job done...
Nachricht 4 von 11
gustavodelucaf
als Antwort auf: Simon_Weel
I tried that, but I need the panels to stop and begin again on the mullions.
Nachricht 5 von 11
hmunsell
Railings and Curtain Panels systems are very pattern driven. If the railing never repeats a pattern it is going to be difficult to use the default tools. As long as you placing it on a flat surface (not sure how well it will work on stairs) your best bet is to use a Curtain Wall. You can make custom panels and swop them out as needed. Use Curtain Grid tool to Add/Remove Segments as needed for the panel sizes.
Howard Munsell
Nachricht 6 von 11
blank...
Create just one family for posts. You will have to have several post family types if you want clips to face the right way.
Then create the glass as a simple glass "wall" and go crazy with Edit profile.
Nachricht 7 von 11
Simon_Weel
You have to create multiple segments for the panels. It's convoluted, so I guess you're better off using a Curtain Wall?
Nachricht 8 von 11
gustavodelucaf
als Antwort auf: blank...
Does Revit understand the gaps between the walls, created using edit profile, in material takeoff and wall schedule?
Nachricht 9 von 11
blank...
Hmmm
No, as far as I know.
Nachricht 10 von 11
gustavodelucaf
I'll just create several walls then.
Thanks for the suggestion.
Nachricht 11 von 11
blank...
I struggled trying to implement curtain walls as a solution for this, but they always break apart when it comes to anything even remotely "complex", just a regular stairway is enough to make them refuse to work.
