Why can't I export the area property of the room using the 3D view?
franciane_pereira9Z2WH
Hello everyone,
In my project I am exporting an ifc file using 3D view, but the area of ​​the rooms is not exported.
But if I try to use the floors view, the rooms area is exported successfully. Is there any way to export the rooms area using Revit 3D view?
hmunsell
@franciane_pereira9Z2WH wrote:
In my project I am exporting an ifc file using 3D vision,
Not sure what "3D Vision" is, but If you do an Export using the IFC exporter in Revit do you get room volumes?
Howard Munsell
I corrected the view name in this post. I send a print screen of component. I try to export using these view, but the area properties do not appear in the ifcSpace quantitative data after exporting the ifc file.
Yes. The
NetVolume property is showing.
hmunsell
Ahhhh that makes more sense now 😁
Unfortunately (or fortunately depending on your perspective) we don't have to deal with IFC's that much in my office. I can poke around and see what I can find, but maybe someone else will chime in the mean time.
Howard Munsell
Sorry for confusing the view names. rsrs
Perfect, I'll keep waiting for help here.
Thank you very much.
