Hi there… i just used curtain wall tools in revit
10 REPLIES 10
Message 1 of 11
FacebookGroupMember
229 Views, 10 Replies
Hi there… i just used curtain wall tools in revit. Anybody has an option on how to make the border joint? 🙏 would like it to join as in the image in the right.
10 REPLIES 10
Message 2 of 11
Join Geometry command?
Message 3 of 11
Message 4 of 11
Nick Schwertschlag thanks but it doesnt work. Still figuring out😀
Last option i will try adaptive component. Just wanna see what are the extent of this curtain wall tool.
Message 5 of 11
Not sure if a chamfered profile join on a mullion is possible but try this: Select the mullion and you should see crosshairs appear near the ends. Click each one to run through the join options and see what happens. 🤷🏽‍:male_sign:
Message 6 of 11
Nick Azbell tried this one too. What i can think through is revit cant read the mullion shape, it reads the mullion as a rectangle or square. 🤔
Message 7 of 11
Use these symbols & Modification tools above
Message 8 of 11
Surya Rajput tried this one too😄
Message 9 of 11
Mohd ACip Norashibli Then plz go to edit properties of this you will find many related options
Message 10 of 11
First unpin this to make it editable
Message 11 of 11
Mohd ACip Norashibli secondly there is also a size problem...this is too small partition maybe you need to change the size of the partition grid ..or the mullion
Forma Design Contest
