Show only
Search instead for
Hi there… i just used curtain wall tools in revit. Anybody has an option on how to make the border joint? 🙏 would like it to join as in the image in the right.
Nick Schwertschlag thanks but it doesnt work. Still figuring out😀 Last option i will try adaptive component. Just wanna see what are the extent of this curtain wall tool.
Not sure if a chamfered profile join on a mullion is possible but try this: Select the mullion and you should see crosshairs appear near the ends. Click each one to run through the join options and see what happens. 🤷🏽:male_sign:
Mohd ACip Norashibli secondly there is also a size problem...this is too small partition maybe you need to change the size of the partition grid ..or the mullion
