Hi everyone,
My walls aren't joining properly even when I drag the wall ends or trim them to connect. I've also allowed wall joints too so I'm not too sure what the issue is. Thanks for helping
Hi @parkside125
Is this a single storey building, are there walls above or below the walls pictured that they may be joining to?
Also, when you select the each wall, do you see a T shaped icon at the end of the wall? If so, click on the icon, to allow the wall to join, then trim the walls to join.
post that portion here so we can check? thanks
