Herringbone 150 x 900 mm Hatch Pattern
7 REPLIES 7
Message 1 of 8
7312 Views, 7 Replies
I am really struggling with creating a hatch pattern for 150 x 900 mm
Can anyone assist me?
7 REPLIES 7
Message 2 of 8
Download the pyRevit plugin
You can draw patterns in a project using detail lines then assign them to a material or export them as a .pat file to import to other projects.
Message 3 of 8
hugha
Try this:
; Written by HatchKit Team Edition
; HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2019-10-24
;-Time : 23:34:57
;-HatchKit Team Edition Version : 3.1.11.2776
;-HatchKit Team Edition Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*Herringbone150x900,LEFT-HAND 150mmx900mm weave=1/1
;%TYPE=MODEL
0,0,0,1650,-150,1050,-750
90,150,0,1650,150,1050,-750
hth,
Hugh Adamson
Message 4 of 8
indiana_j0nes
Message 5 of 8
in reply to: hugha
Hi there, thanks for the assistance. It kind of works but is on a diagonal. Anything I can do to make the pattern go correctly?
Message 6 of 8
in reply to: indiana_j0nes
I tried this one and it does not work
Message 7 of 8
hugha
try this instead,
;-Date : 2019-10-25
;-Time : 00:48:12
;%VERSION=3.0
;%UNITS=MM
*Herringbone150x900@45,LEFT-HAND 150mmx900mm weave=1/1
;%TYPE=MODEL
135,106.07,106.07,150,-150,1050,-750
45,0,0,150,150,1050,-750
hth,
Hugh Adamson
Message 8 of 8
Pattycake_Kyle
Hey @Anonymous - Can you reply here or email us hi@pattycake.io with what wasn't quite working? And thanks @indiana_j0nes for the shout out.
Testing it out on our end it seems to work (see below). You can also adjust angle degree to keep reiterating any size / rotation you need while seeing a live update and just simply click [download] to get the PAT file already formatted.
Quick note: This current Calculator Template can only handle whole divisible segments but in our Version 01 launch coming <1 week, we have updated to allow fractional remainders between width and length 😎
As a note for the community: We know that the herringbone pattern is one of the most requested PAT patterns on this forum. As a big thank you to the community and everyone helping develop this program and provide feedback, we are going to unlock the herringbone calculator template in version 01 to be completely free! All you'll need is a free account to access the calculator and you can then reiterate and save countless herringbone creations. (this in addition to over 350+ free PAT patterns).
Keep on Pattycaking, and more on version 01 here: https://youtu.be/nmq2GVScwu8
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Forma Design Contest
