Hello again. In my previous question I solved how to do a modified sloped roof. Here I came across another issue which you will see in the attached photos:
Components are attached from the first 2 points of the section
Components not attached as you move in the section
What I want to do is this:
1. How can I keep the roof but add traditional tiles in the direction of the sloped roof?
2. How can I adjust the Bamboo and the Circular Wooden Beams to follow as well the angle of the Roof?
**Clay and other Materials are incorporated inside the Roof so this is not an issue.
Thank you again for your time!
All the Best!
Are you wanting to model the Beams? I'd use a Beam System for that. The rest of the roof build-up could be done using a basic roof containing all layers (you could turn it into Parts as well), or series of basic roof stacked on top of each, each representing one layer.
If your intent it to model the tile, then that would best be accomplished via a Divided Surface with Pattern-Based Panels applied to it.
Are you familiar with all these processes?
Sorry for my late reply and thanks for answering me back immediately.
Due to the fact that the existing model geometry is not 'perfect' I am having difficulty to set any parameters and model.
I somehow tried these steps but no, unfortunately, I am trying to learn Revit through this project, so I am new to all of the procedures. Thank you very much!
