Guys I need to inset a pump in a piping system
FacebookGroupMember
FacebookGroupMember
Guys I need to inset a pump in a piping system. Can you help.using Revit 2022.
Rak.Marcelo
Hi, let me help...first you need to load a family...either you already have a pump family and you use Insert Family option, or you dont have family, but you can load one which already comes with the Revit using Systems--->Mechanical Equipment--->Load--->Find folder Metric/Imperial--->Mechanical--->Water side Components--->Pumps---Load any pump which is best representation of a pump component in your system....The final step is only to position that pump into the system and use its connections points to the prearranged pipes...BR
FacebookGroupMember
Autodesk Community thank you very much...team. I just couldn't find the right folder in the liabry which is my problem. I am using Metric measurements so yep...thanks, let me try it and I will inform you.
Rak.Marcelo
hope it helped
