gap between vertical and slanted coloumn
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
868 Aufrufe, 16 Antworten
any body knows how to join between slanted and vertical coloumn ?
There is a gap and it cannot be joined with join geometry .
16 ANTWORTEN 16
Nachricht 2 von 17
ennujozlagam
als Antwort auf: Anonymous
your file no column attach? thanks
Nachricht 3 von 17
i am sorry here the file
Nachricht 4 von 17
als Antwort auf: ennujozlagam
sorry Here is the file
Nachricht 5 von 17
ennujozlagam
just add a reference plane > pick your column > attach top/base. thanks
Nachricht 6 von 17
are they coped? Zero out the coping distance.
Nachricht 7 von 17
thanks a lot... i understand now...
Nachricht 8 von 17
als Antwort auf: barthbradley
no i have tried with grid line also
Nachricht 9 von 17
ennujozlagam
not grid line. use reference plane to attach. pick your column and set maximum intersection before attach base /top. thanks
Nachricht 10 von 17
how to add ref plane in coloumn ? should i edit the column with edit family ?
Nachricht 11 von 17
it failed
Nachricht 12 von 17
I don't understand what you are trying to do. Some Copperfield sh*t or what?
Nachricht 13 von 17
hi i tried but it failed... what happened? thanks
Nachricht 14 von 17
ennujozlagam
detach and attach your column. thanks
Nachricht 15 von 17
thanks a lot i just dont click maximum intersection...
Nachricht 16 von 17
ennujozlagam
that's good, you got it. thanks :grinsendes_Gesicht_mit_Schweißperlen::zwinkerndes_Gesicht:
Nachricht 17 von 17
RDAOU
@Anonymous
While the suggested method from @ennujozlagam solved the issue, here are a couple of tips
  1. Giving an offset to the vertical column and using join geometry is another way of cleaning out joins
  2. If you properly model/place the columns, using the coping tool is another option to join a vertical column to a slanted one
  3. Slanted columns behave like beams. That being said, instead of slanted columns you could use Beams
