In Revit area schedule, I am trying to take the "Grand Total" in an Area schedule then use it in a calculated parameter.
Is this possible? Please see image capture below. I appreciate any pointers.
Solved by ralphdenhaan. Go to Solution.
See print screen:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Thank you @ralphdenhaan. This worked well and I will accept it as solution.
Can I ask another question: how can I take the grand total and put it in calculated parameter. Please see capture below.
Something like this?
This is the formula for the grand total, and you can add anything you like to it?
Ralphdenhaan,
I have a question to ask regarding your solution.
What if i divided the areas into GFA and nonGFA portion, some of the area would appears to be 0, how could i do the similar trick to have calculated value appears on both GFA/nonGFA portion?
Leonard
