Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Grand Totals inside Calculated Formula
zakim
Message 1 of 8
zakim
In Revit area schedule, I am trying to take the "Grand Total" in an Area schedule then use it in a calculated parameter.
Is this possible? Please see image capture below. I appreciate any pointers.
Replies (7)
Message 2 of 8
ralphdenhaan
See print screen:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 3 of 8
zakim
Thank you @ralphdenhaan. This worked well and I will accept it as solution.
Can I ask another question: how can I take the grand total and put it in calculated parameter. Please see capture below.
Message 4 of 8
ralphdenhaan
Something like this?
Message 5 of 8
zakim
Not really. I would like to take the "Grand Total" value and multiply it by a factor (e.g. 0.3
Message 6 of 8
ralphdenhaan
This is the formula for the grand total, and you can add anything you like to it?
Message 7 of 8
archimotto
Ralphdenhaan,
I have a question to ask regarding your solution.
What if i divided the areas into GFA and nonGFA portion, some of the area would appears to be 0, how could i do the similar trick to have calculated value appears on both GFA/nonGFA portion?
Leonard
Message 8 of 8
ct_studio
I am trying to do something similar. I want to multiply the number of parking spaces by a factor to produce the allowed number of units.
I'm not sure how to use the grand total in the formula field:
