Glass divided on corner
6 REPLIES 6
LanggamanXavierMassed
559 Views, 6 Replies
I have extruded a sloped glazing and the finished glass tend to separate on the corner. I think what causes this is it is allotting a space for a mullion? I need this to be continuous, system panel family and the overall curtain wall properties is shown
6 REPLIES 6
Redrunner92
That is going to be an expensive piece of glass. Fabrication, shipping, and labor to install it will be quite costly if it's one single piece.
I don't believe a curtain wall panel will make that change in planes without a break in the glazing panes.
yes that is true but they only have to touch each other, not as 1 whole piece of glass
...if you need it to be continuous, use a basic roof of the same thickness and material as the sloped glazing.
bin
in reply to: LanggamanXavierMassed
bin
You can change the offset of the panel to 0 and adjust the mullion offset instead.xxx001.PNG
in reply to: bin
oh I understand now!  the panel is created parallel on the extrusion lines because it's being offset, but it does not automatically join and is only projected perpendicularly.  I put the offset to 0 and it's ok now
Yes, that exactly what I was pointing out in my screenshot above.  I figured the picture was worth a thousand words. TAB-Select the individual Panels and use can adjust each Instances "Extrusion Start" and "Extrusion End" Properties.
