Message 1 of 9
We have several families with symbolic "clearance zones" built in. When they are tagged, the leader will center on the clearance zone, and it drives the designers nuts to go and manually fix them all. I tried to change the lines to be "not a reference" but that doesn't work. Only invisible lines do the trick, which defeats the purpose.
I have also tried to have a visibility parameter on the families for the clearance zones, turn them off to tag, turn them back on, but then the leader still points to the symbolic lines. Anything I'm not thinking of? Thanks!
