Generic model not offsetting from same level
I've created a generic model family, which I use as fasade panels. On the attached elevation it is possible to see that the panels, eventhough offset in the same 65mm, they are not aligned.
The two highlighted families are the same. They are places from the same view/level.
They both constrain to the same Level: Plan U2 but they host to either floor or Level.
I have used the Autodesk family template: Metric Generic Model.rft to create them.
Why are they hosted? Why are they hosted to different things?
I need to offset all the wall panels at once by using the offset option in properties.
Hope somebody will be able to help me. Thanks in advance.
/Kasper
SOLVED!
1: PICK NEW HOST
2: Select desired level.
