Formula for a min/max length parameter that varies depending on yes/no parameters
6 REPLIES 6
lchiossoneLCKJ2
553 Views, 6 Replies
I'm trying to make a min/max formula that varies depending on which yes/no parameter is ticked.
I can make the min/max formula, but don't understand how to the add the yes/no parameters to it.
Basically, when standard is ticked, I want the minimum height to be 1000mm and the max to be 3000mm. And when reinforced is ticked, I want the minimum height to be 2000 and the max to be 6000mm.
Thanks!
Snips below for help
6 REPLIES 6
in reply to: lchiossoneLCKJ2
Share the family here.
if(Standard, standard equation, reinforced equation)
Sample family
Try this
Thank you! This has worked! Just made some slight alterations to the min/max parameters.
Good that worked!!
But you put the solution tick in your own reply hhehehe
Forma Design Contest
Technology Administrators
