I'm trying to make a min/max formula that varies depending on which yes/no parameter is ticked.
I can make the min/max formula, but don't understand how to the add the yes/no parameters to it.
Basically, when standard is ticked, I want the minimum height to be 1000mm and the max to be 3000mm. And when reinforced is ticked, I want the minimum height to be 2000 and the max to be 6000mm.
Thanks!
Snips below for help
Solved by lchiossoneLCKJ2. Go to Solution.
Share the family here.
Toan Nguyen
Thank you! This has worked! Just made some slight alterations to the min/max parameters.
