Can someone see why my second floor doesn't show in floor plan.
Its clearly there in 3D
Thanks!
Solved by RDAOU. Go to Solution.
Your View Detail is set to Wire Frame... change to Hidden Lines or Shaded
Otherwise, if it still doesn't show,
if you can select the floor in plan then right click and go to override graphics in view and confirm the VISIBLE button is checked,
