Floor doesn't show
Floor doesn't show
glkirk
Floor doesn't show
glkirk
Can someone see why my second floor doesn't show in floor plan.
Its clearly there in 3D
Thanks!
RDAOU
@glkirk
Your View Detail  is set to Wire Frame... change to Hidden Lines or Shaded
Otherwise, if it still doesn't show,
  1. check if it is hidden using the bulb?
  2. check in Visibility Graphics if category is switched off
  3. check if an override has been applied and it is set to transparent
  4. ...or check if it any of the 40+ reasons LISTED ON THIS LINK and THE LINKS THEREIN
kadmonkee
if you can select the floor in plan then right click and go to override graphics in view and confirm the VISIBLE button is checked,
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
glkirk
Thanks very much!  It was the line style, it was set to wire frame.
Thanks again!
